P0327
2008CobaltOwner
Ontario
Hi,
my 2008 2.2L base model threw P0327 after sitting for several days in rainy weather. I erased the code, and it did not come back for a month while weather was dry and hot. Then it again sat for 4 days in rainy weather and the code returned. Erasing it does not help anymore. I decided to replace the knock sensor. This did not help. Does anybody know what is the typical cause of P0327 on Cobalts?
Scottrod
Winnipeg
I found the wiring harness was rubbed through where it was against the oil filter housing causing it to short and throw the same code.
