Fuel System
Fuel System FAQ
This FAQ was made to make things more understandable for the newer and avid car enthusiast who is looking to modify and upgrade their vehicles fuel system but they have some misconceptions or misunderstandings on the fuel system.
I tried to make this as simple to understand as possible while getting some details into it.
Special Thanks to Witt & Scott @ Cobalt Performance Parts
What is a fuel systems job?
A fuel systems job is mainly to maintain a proper fuel demand throughout the system that will eventually be sprayed from the fuel injectors into the intake stream and into the combustion chamber.
What does a Fuel System Consist Of?
This depends on if it is a return or return-less fuel system. If it is a return fuel system, it has a fuel tank, fuel pump, sending fuel lines (from the pump to the fuel rail), a fuel rail, fuel injectors, fuel pressure regulator and returning fuel lines to the fuel tank. If it is a return-less fuel system, it has the same items but no fuel pressure regulator and return fuel lines.
How does a return fuel system work?
A return fuel system first starts out in the fuel tank. Everyone knows you go to the gas pump and put fuel into your gas tank, so that’s where it originates. Typically, the fuel pump is located inside the fuel tank. The fuel pump sends the fuel from inside the fuel tank through the fuel lines (sending lines). This fuel being sent is sending a high pressure to the fuel rail. As it enters the rail, fuel tries to either be sent back to the fuel tank or into the fuel injectors themselves. What keeps all the fuel from going back to the fuel tank? The fuel pressure regulator. The fuel pressure regulator will determine the amount of fuel being returned or staying inside the fuel rail. Also, by restricting the fuel line, it’s increasing the pressure inside the rail which effects the amount of pressure inside the fuel injectors and how much fuel is being sprayed out during the injectors cycle. After this, fuel that is not being used is now sent back to the fuel tank via fuel return lines (which were attached to the fuel pressure regulator). Fuel returns to the fuel tank and the cycle of fuel starts all over.
How does a return-less fuel system work?
Very similarly to a return fuel system except fuel is not sent back to the fuel tank if it’s not being used, hence, it doesn’t have an fuel pressure regulator to “regulate” fuel being sent back to the fuel tank. There are a couple of ways that fuel is maintained. On a return fuel system, fuel being sent from the fuel pump is sent at a constant rate, on some fuel systems, the fuel pump fluctuates depending on the voltage sent to the fuel pump from the computer. The computer decides when more fuel should be sent and it also determines when there should be less fuel sent. Other return-less fuel systems have a valve inside the fuel pump itself that can change the flow rate of the fuel pump.
What is every items job specifically?
1. Fuel Tank – To store fuel a certain capacity of fuel (gasoline)
2. Fuel Pump – To send the fuel towards the fuel rail via fuel lines (sending lines)
3. Sending Fuel Lines – To carry the fuel that was sent from the fuel pump to the fuel rail
4. Fuel Rail – Fuel rail is the central area where fuel comes to from the fuel sending fuel lines. The fuel that ends up here either gets pressurized into the fuel injectors or (on a return fuel system) gets sent back to the fuel tank.
5. Fuel Injectors – Fuel injectors job is to open and close at certain times on a 4 stroke engine (during the intake stroke). As it opens, it sprays fuel into the air intake stream which will get carried into the combustion chamber. Throughout the rest of the strokes, it remains closed.
6. Fuel Pressure Regulator – It is a device that is on the end of your fuel rail. On most units, there is a vacuum reference line that is connected to the intake manifold. As vacuum pressure drops (nearing towards atmospheric pressure), a spring inside the fuel pressure regulator tightens against a diaphragm which will start to restrict fuel from returning to the fuel tank. As it restricts fuel, it is also raising the pressure inside the fuel rail. Fuel pressure rises and drops according to the vehicles condition, whether it would be idle, cruising or wide open throttle. This item is only found on return fuel systems, NOT return-less fuel systems.
7. Fuel Return Lines – Carries fuel back to the fuel tank which the cycle of fuel starts over again. Once again, this item is only found on return fuel systems, NOT return-less fuel systems.
When should I change my fuel injectors?
You only change your fuel injectors when they are starting to exceed a certain duty cycle. The industry standard is 80% - 85% duty cycle maximum that a fuel injector should flow. Anything higher, you run the risk of overheating from the kinetic energy that they produce which will cause them to not open/close efficiently or just plain failure.
What is duty cycle?
Duty cycle is referring to the time that an fuel injector is open divided by the time that it can possibly be open during two complete engine revolutions.
Ok, I want to build up my car but I’m not sure what size fuel injectors to get. How do I find out what size I need?
This is a very common question asked. First, understand the point of changing your injectors is to maintain a certain demand of fuel to your engine from your fuel system as efficiently and reliably as possible.
When shopping for fuel injectors, understand that fuel injectors are also rated by fuel pressure. Fuel is being sent as high amounts of pressure which are typically measured by PSI. Lets use for example, you find fuel injectors that are 42 lbs/hr rated at 40 PSI of fuel pressure. Your car might run it’s highest at 50 PSI of fuel pressure. If you were to put these 42 lbs/hr injectors are going to be spraying more lbs/hr than the original rating just because of the increase in fuel pressure on your vehicle compared to their original rating. This might or might not what you would be aiming for depending on what you’re using to control the injectors throughout idle, cruising speeds and wide open throttle but this is what you would have to shop for.
NOTE: Industry standard for fuel injector rating is about 45 PSI of fuel pressure (3 BAR of fuel pressure)
Now, what size do you need? There is a very good calculation that you can use to give yourself a good accurate answer:
Flow Rate = (Horsepower x BSFC) / (# of Injectors x Max Duty Cycle)
Ok, you’re probably thinking “what the hell is BSFC?”. BSFC stands for brake-specific fuel consumption which are rated in pounds per hour. The average for naturally aspirated engines is about 0.45 and for turbocharged engines about 0.55 at full throttle (It could normally be anywhere from 0.4 to 0.6). Like said, these are estimations but it will give you a good idea.
Lets use an example:
Say you have a 2003 Pontiac Sunfire with a 2.2 ECOTEC and you’re looking to turbo-charge it but you want to know the proper size injectors to get. Your goal is 300 Horsepower (flywheel horsepower). It’s a 4 cylinder engine, so it has 4 injectors and the max duty cycle I’m looking to ever go to is 80%. So lets do the math…
Flow Rate = (300 HP x 0.55) / (4 x .80)
Flow Rate = (165) / (3.2)
Flow Rate = 51.5625
So I just figured out that if I wanted an estimate of 300 flywheel horsepower and don’t want to exceed 80% duty cycle, I would need fuel injectors that are about 51.5 lbs/hr and this is also understanding 51.5 lbs/hr at whatever given rating of the fuel pressure.
What is the difference between low and high impedance injectors?
The amount of voltage an injector needs to open. High impedance basically means it needs a higher amount of voltage sent to the injector to have it open fully and properly. Lower impedance injectors are just vice versa. High impedance injectors as far as voltage go need anywhere up to 12 Ohms, low impedance are around 3-5 ohms but of course, this depends on the vehicle and engine management system.
Do I need to upgrade my fuel system if I run a nitrous kit? (wet or dry kits)
Not to get too off topic but a brief description of how each kit works and why you would or wouldn’t need to upgrade with either one. I am assuming that you already know how nitrous affects an engine as well:
A wet nitrous kit basically means that as nitrous is being injected into your air intake stream it is also spraying fuel to keep a well balanced air fuel ratio inside your combustion chamber. Depending on how this kit is installed and the vehicle you’re using, you can either tap into the fuel line or the fuel rail for a source of fuel.
Do you need to upgrade your fuel system on a wet kit? Depends. Your fuel injectors, no you don’t need to upgrade them because the fuel that you are supplying along with the nitrous is coming from an outside source and not being sprayed through your fuel injectors. Your fuel pump, maybe. Depending on the stress that is made on the fuel pump to keep a certain demand of fuel (GPH), it might need to be to keep from starving the fuel injectors as well as keeping your “wet line” supplied with enough fuel.
Do you need to upgrade your fuel system on a dry kit? Yes (or at least I suggest it). With a dry kit, you’re just spraying nitrous alone and now you’re taking the fuel management side into your own hands by relying on your fuel system for fuel supply during nitrous injection. Same rules apply as far as overworking your injectors or fuel pump. It’s all about maintaining a proper fuel supply and demand. When things are off balanced and over looked, bad things will start to happen which typically results in lean air/fuel mixtures if it’s not adequate enough during a dry shot injection.
Some cars have return-less fuel systems and some have return fuel systems. Why is it like this? What’s better for performance?
Return-less fuel systems were created, for one, help the computer control more of the amount of fuel being sent to the fuel rail and to also reduce on the likeliness of fuel leaks by reducing the amount of lines used.
What’s better for performance? Return fuel systems are. They are better for performance in the aspect that all fuel that is entering the rail is entering the fuel injectors at an about equal rate and they are getting an about equal amount of fuel. What typically happens with return-less fuel systems is that as fuel is coming in from one side of the fuel rail, it might be starving the farther injector(s), so they aren’t getting sufficient amount of fuel into the injector(s), hence, not supplying the proper amount of fuel into the combustion chamber which could result in lean mixtures that cause detonation & possible engine damage. Now, this is of course speaking from a high performance point of view and not necessarily in a stock or near stock situation.
What are rising-rate fuel pressure regulators?
Rising rate fuel pressure regulators basically do the same job as your stock (OEM) fuel pressure regulator. Your stock fuel pressure regulator raises fuel pressure as vacuum pressure drops. It has a line that connects from the fuel pressure regulator to the intake manifold to read the air pressure inside the manifold, which helps determine the desirable fuel pressure inside the fuel rail.
On an OEM unit for a naturally aspirated engine, if you were to turbo-charge the engine, as you’re increasing above atmospheric pressure (boost pressure), it will rail fuel pressure inside the fuel rail on a 1:1 ratio (for every pound of boost, it will raise the fuel pressure 1 PSI inside the fuel rail).
On an rising rate fuel pressure regulator, depending on the unit, it will raise the fuel pressure higher than the OEM 1:1. It can be anywhere from 6:1 to 12:1 ratio of fuel pressure to boost pressure.
Increasing fuel pressure will also increase the amount of fuel going through the fuel injector every time it opens but also understand that too much fuel pressure on an underrated fuel injector can cause that fuel injector to not operate properly from internal damage. Another thing to look out for is your fuel pump (which will be explained) as it is also rated to send a certain amount of fuel to your fuel rail. As you’re increasing pressure by restricting the amount of fuel returning to the fuel pump, you’re also slowing down the amount & speed of the fuel to travel from the pump to the fuel rail. Basically, as you’re increasing pressure, you’re also decreasing the rating on the fuel pump.
I want to get a new High Flowing Fuel Pump, which one should I get?
Once again, changing the fuel pump is to keep up with the demand of the rest of the fuel system. Your fuel pump is rated typically either by lbs per hour or gallons per hour.
As you shop for a fuel pump, you will run into different descriptions of the fuel pump, which will refer to: Capacity (lbs/hr or gph), Voltage & Fuel Pressure (PSI). The fuel pressure part is referring to the amount of fuel pressure that in the fuel system that your fuel pump has to constantly supply towards.
The equation to figure out what fuel pump you would need is as follows:
Flow Rate = Horsepower x BSFC
Flow Rate = X lbs/hr
So lets use an example:
Say you have your, once again, 2003 Pontiac Sunfire with a 2.2 ECOTEC engine. Your goal is 300 Flywheel Horsepower with a turbo-charger, you’re assuming 0.55 BSFC, and your constant fuel pressure is 50 PSI.
Flow Rate = 300 x 0.55
Flow Rate = 165 lbs/hr
Now, if your fuel pump you’re shopping for is rated in gallons per hour (GPH), then you take that number and divide it by 6. Your answer is 27.5 GPH.
What happens if I don’t provide enough fuel for my engine?
Your engine is basically meted by a certain amount of air to fuel. You basically need air in order to burn fuel. If there isn’t enough fuel being supplied, this can cause it to run into what is called a lean condition. Lean conditions can cause improper combustions to knocking (detonation) and quite possibly engine damage depending on how bad the condition is.
Can I use fuel injectors from another car?
Yes. The most common fuel injector is the Bosch pintle type injector, if you’re able to find larger injectors that are the same style as your vehicles, you should be able to use those injectors.
If I wanted brand new injectors, what manufacturers can I buy from?
Bosch, Accel, RC Engineering for starters.
If I wanted to buy a new fuel pump, what manufacturers can I buy from?
MSD & Walbro are bigger name companies. You can check them out and see if they have a fuel pump that is rated for your application’s fuel system needs.
How do I convert flow rates? What’s the calculation?
To convert from CC/Min to Lbs/Hr
CC/MM = lbs/hr x 9.71
To convert from lbs/hr to cc/min
Lbs/hr = cc/min x .103
Gallons Per Minute = (lbs/hr) / 369.8
typo at high impedance injectors.. it's not the fact that they need ohms they simply are ohms(resistance) also "voltage" is not relative to the statement that he is attempting to make.
---------- Post added at 08:08 PM ---------- Previous post was at 07:35 PM ----------
and lean mixtures cause preignition not detonation. By definition preignition happens before the actual spark and detonation is after.
otherwise some solid information.
ah oh well i may leave it as is and with your post make people think...nice sig btw
