P0010 Code...Easy Fix?
Discussion in 'LS, LT, LTZ' started by Trussell, Mar 6, 2012.
  1. Trussell
    Trussell Junior Member
    20
    Feb 5, 2012
    Hello again
    I have a check engine code P0010 which is Intake Camshaft Position (CMP) Actuator Solenoid Control Circuit
    is this an easy "do it yourself" fix or better for a mechanic to fix?
    Thanks
  2. YelloEye
    YelloEye Super Moderator Staff Member
    7,608
    25
    What year and motor (2.4 LE5, 2.2 LAP, 2.0 LNF) do you have?
  3. Trussell
    20
    Feb 5, 2012
    Sorry about that
    09 LT Automatic 111,000 miles 2.2L
  4. YelloEye
    7,608
    25
    No worries, one could assume that it was a 2.2 since you posted in the LS section, just wanted to be sure.
    Here's what the GM Service Manual says for that code.
    So things you need to check:
    Oil, is it at the correct level, of the correct viscosity and when was it changed last?
    Check the resistance of both of your CMP actuator solenoids, they should be 8-12ohms
    If you find the solenoid that is bad (it'll be the one closest to the front of the car) it's pretty cake to replace if you know your way around a set of hand tools. I'll post instructions in a minute.
    Images didn't show up so here's an image that I can explain from. Cyl 1 is on the passenger side of the motor, just to the left of that spark plug coil are 2 smaller plugs, those are the cam actuators. You want to disconnect and remove the one closest to the front bumper. In my picture there's a long ziptie end that runs right over the top of them. Just squeeze the clip and pull to remove the connector.
    [​IMG]
    Best of luck, I would make sure it doesn't need new O-rings first, and if everything else appears fine I would replace the actuator.
    Here's what I believe the part number is 12628347 Make sure to verify with a local dealership that this is the correct part for your car. GMpartsdirect.com has it for $29.91+shipping. Dealer will want at least $50.46.
  5. Trussell
    20
    Feb 5, 2012
    Thanks....I will try this tomorrow
  6. Trussell
    20
    Feb 5, 2012
    That fixed it...Thanks again!
  7. YelloEye
    7,608
    25
    Did you end up needing to replace the pay or just an o-ring?
  8. Trussell
    20
    Feb 5, 2012
    Sorry the late post, but I replaced the part
  9. cjsdad
    cjsdad Junior Member
    Sep 3, 2012
    where did you order the part from dealer or the website
  10. BankDude
    BankDude Full Access Member
    27
    384
    Sep 29, 2010
    probably online. old thread
Share This Page
