P0300 code! Help
Discussion in 'TSB's' started by 07cobaltsssc, Mar 23, 2010.
  1. 07cobaltsssc
    07cobaltsssc Full Access Member
    111
    Mar 23, 2010
    Woodbury, MN
    Alright, well i have a p0300 code and my cel light is on and i can hear a misfire through the exhaust. What have done to this car is OTT Stage 2, which includes 60 lbs injectors, ott tune, 2.8 pulley, step colder plugs, cai, centerforce dual friction clutch, zzp s3 heat exchanger. OTT told me that it could be the plugs or the injectors. A couple days ago i pulled the plugs and they were black on the bottom. I called Hitech motorsports and asked them what could be wrong and he said it could be something with the tune. I ordered a scanner a couple days ago as well. I really need to figure out what is wrong here before i want to get it back out on the roads. Also, i have a air fuel gauge and the numbers are bouncing up and down and ott says that is normal for that because of safety precautions. Any help from you guys would be greatly appreciated.
  2. utsadude
    utsadude Platinum Member
    1,254
    Columbus(boring), TX
    I assume your AFR gauge is a wideband?
    If so, what does it read at WOT?
  3. 07cobaltsssc
    111
    Mar 23, 2010
    Woodbury, MN
    Yeah its is wideband.
    When my buddy was looking at it, it said between 10.9 and 11.1.
  4. utsadude
    1,254
    Seems a little rich.
  5. 07cobaltsssc
    111
    Mar 23, 2010
    Woodbury, MN
    Yeah thats what i think, and then i called OTTP and they told me that they have there tune made richer for safety precautions or something like that.
  6. utsadude
    1,254
    Get a real tune.
  7. 07cobaltsssc
    111
    Mar 23, 2010
    Woodbury, MN
    Thats what i am thinking about, but a custom tune is $550 and i kinda dont want to go that way but if i have to i will.
  8. utsadude
    1,254
    Where are you from?
  9. 07cobaltsssc
    111
    Mar 23, 2010
    Woodbury, MN
    From minnesota
  10. ff_drift_lol
    ff_drift_lol Full Access Member
    30
    2,138
    Nov 27, 2009
    long island, new york
    thats not really that rich... should be low 11 high 10 range wot. stop using boxed tunes! every car is different, you need to have someone tune you with hptuners and data log you until it's right. or get dyno tuned.
    550 is ridiculous. should be about 200 since it's like 50 bucks to license the vin with hptuners. the rest is up to the tuner.
Share This Page
