PI: RPD intermitent signal
rukkee
WNY
Service Information
2009 Chevrolet Cobalt | Cobalt, G5 (VIN A) Service Manual | Preliminary Information | Document ID: 2470794
#PIC5350: Intermittent IPC Gauges WOW Multiple warning Lights On May Or May Not Have Codes P0575 U0140 U0121 U0073 P0703 Set - keywords ABS boost cluster communication DTC gage gauge inop inoperative IP light - (May 12, 2010)
Subject: Intermittent IPC Gauges WOW, Multiple Warning Lights On, May Or May Not Have Codes P0575 U0140 U0121 U0073 P0703 Set
Models: 2009 - 2010 Chevrolet Cobalt W/UAF Configurable DIC
Condition/Concern:
Some customers may comment that the IPC gauges WOW and/or multiple warning lights are illuminated. Upon inspection technician may find DTC's P0575 U0140 U0121 U0073 P0703 stored.
This may be caused by a pinched harness between the I/P carrier and body mount.
Recommendation/Instructions:
Remove IPC & instrument panel cover to gain access to the configurable DIC harness. Inspect harness 14 inches from display at the IP carrier mount on left side of dash for pinched wiring - See attached photos.
See SI Document ID: 1378906 for approved GMLAN wiring repairs.
© 2010 General Motors. All rights reserved.
rukkee
WNY
I know ..... I need to stop by here more . NP on the TSB... I'm just happy that you guys made a spot for them .
I've posted TSB's on .net for years...... They are so buried that you can't find crap. I asked for a sticky to list them all in and never heard back.
UncleDave
High in Colorado, in a Valley
Started to look at the problem. U 0073 P 0700.
Removed the engine cover. Quick look showed that the block casting around the oil filter has a rather sharp corner, which is biting into the wiring harness that is being pushed up against it. Taped it up as good as I could. Filed down the corner so it is not as sharp.
Problem will be that it will be hard to prove that this is the fix. Sure is MICKEY MOUSE.
Used to do my own service. Find that the Air Filter was missing the Neopreme collar allowing dirt to get past it the element.
