USMCFieldMP COTM Submission
Status
Not open for further replies.
USMCFieldMP
Findlay, Ohio
Name
Robert - USMCFieldMP
Findlay, Ohio
Car Info
2005 Victory Red Chevrolet Cobalt SS
Stock Options
XM Satellite Radio, Sunroof
Modifications
-Custom T3 Turbo Manifold
-Precision HP5557E w/ Billet Compressor Wheel (.63A/R T3 Turbine Housing w/ V-Band Outlet)
-Custom Downpipe
-Tial 38mm Wastegate
-Custom ZZP Wastegate Dump Tube
-Custom ZZP Charge Piping
-ETS 2G DSM 7" Street Intercooler
-Tial Blow-Off Valve
-Hallman Pro MBC
-Vulcan Short Runner Intake Manifold
-ZZP Phenolic Intake Spacer
-80 lb/hr Injectors
-Custom ZZP Return Style Fuel System w/ Fuelab AFPR & Walbro 255LPH pump
-ZZP Triple Gauge Pillar
-Auto Meter ES Series Mechanical Boost Gauge
-Auto Meter ES Series Pyrometer Gauge
-Auto Meter ES Series Oil Pressure Gauge
-Auto Meter ES Series Wideband
-Aeroforce Interceptor
-08+ FE5 Shocks & Struts
-Pedders Springs
-Powergrid Sway Bar End Links
-Powell RaceShop Stg2 Rotated Transmission Mounts
-Powell RaceShop Spherical Control Arm Bushings
-Powell RaceShop Prototype Time Attack Rear Sway Bar 1.0
-N2MB WOT Box
-Powerslot Slotted Rotors
-Hawk HPS Pads
-Enkei EKM3's (Custom PC'd "Subaru Gold") w/ 235/40-18 Goodyear Eagle GT's
-Aftermarket Quaife LSD
-Spec Stg2+ Clutch w/ LNF TOB
-B&M Short Shifter
-OTTP Stage 1 Axles
-16" MB Wheels Five X w/ 225/50-16 Hoosier Drag Radials
-Custom Tuned via HPTuners
-EVAP System Delete
I THINK that is everything. 100% Stock Long Block w/ 93,000 miles. Car is currently running ~21.5psi.
Future plans
-GenII Block
-Pauter Rods
-JE Pistons
-Supertech Valve Springs
-Ported & Polished Head
-ID1000's
-E85
-30psi
YouTube - Billet HP5557E Cobalt SS
YouTube - Billet HP5557E Cobalt SS - 2-Step
CBodnar
New Jersey
I've always loved your car. Good stuff! Going to sell it anytime soon? I've been thinking about getting rid of mine and getting a C5 Z06 possibly.
USMCFieldMP
Findlay, Ohio
No plans to sell anytime soon. I'm really close to paying it off actually. I'll probably pay it off... and keep it forever. Haha.
Its time to make the VeeDub fast now, though.
if mine had been a true SS i would have kept it. as it is now discontinued will be worth somethhing later
edrazor
i like your engine bay and the gold rims..... good luck
CFCobalt
the matrix
im still torn between yours and that fresh guy....alot of time and effort into both cars....and both are ridiculously good looking...
USMCFieldMP
Findlay, Ohio
I did when I first put the new turbo on. Had a few problems (Boost Leak) and the system wasn't dialed in at all. 18psi still put down 340/310 on a low reading, Mustang Dyno. That was hitting full boost at 4800rpm too... instead of the regular 4000, because of the boost leak. 22psi + Moar Timing + Boost Leak fixed = 4000rpm full boost = easily 400whp.
:drool: Thats about there I'd like to be with my LNF when I'm done I think, since I plan to do more road racing and autoX than drag.
USMCFieldMP
Findlay, Ohio
Easy Cheesy. Its gotten a lot easier to make big power on a Cobalt in the last year. I might actually sell part of this turbo set-up soon. I'm probably gonna tune this car down a bit. DD it. Put more time and effort into road racing the VeeDub.
Status
mdux1982
