Misfires?
hb_ss/tc
Huntington Beach
Hi guys just registered cause the other site is too busy for me.
Anyways on my interceptor gauge it sometimes shows misfire like pictured below then goes back to 0. I got no CELs tho so should I be worried?
outtamymind
Calgary, Alberta
ya i've come to learn our cars misfire if you blip the throttle and if it doean't shift the way it likes it will as well. from what i can tell its normal
umrdyldo
I get really small amounts of misfires as well. My DashHawk shows all 4 cylinders and get between 1-3 on different cylinders randomly, but it never does it two days in a row.
outtamymind
Calgary, Alberta
well if it starts massively misfiring then worry those little ones could be almost anything. mine does it as well
rukkee
WNY
My old SS/SC used to misfire between shifts and when rev matching a down shift.... since it was new . It never set a code and was more of an annoyance than a problem . I bet that what your seeing , If it doesn't misfire under load than i wouldn't worry about it .
