Aeroforce Interceptor Gauge Sale
The AeroForce Interceptor gauge is 52mm (2 1/16") in diameter and will fit in all standard gauge pods of this size. A 9' cable is included with appropriate OBD2 connector. A splitter cable is included with the dual AeroForce Interceptor units. The gauge comes configured with a black face and bezel but a polished aluminum silver bezel and white face are included.
A function menu is available by pushing both buttons simultaneously. One menu option allows you to enter a record mode. Once selected, the Interceptor will return to normal scan mode, but will start recording the displayed data automatically when the throttle exceeds 60%. Approximately 60 seconds of data will be stored. Returning to the menu screen, you can choose to replay the stored data on the Interceptor display.
The gauge displays 2 parameters at a time, but can be programmed to cycle through up to 8 parameters during a user determined period of time. This way you can monitor several items without taking any other actions.
Another menu option offers the ability to swap the foreground and backround colors of the display. Using this feature, for example, the gauge with a black backround and blue characters (negative image) becomes a blue backround with black characters (positive image.) Positive images are easier to read in bright sunlight, negative at night.
DTC's (Diagnostic Trouble Codes) can be accessed and cleared via menu options.This essential feature will help the gauge to pay for itself the first time the check engine light comes on.
The two analog inputs can be configured through menu choices. A linear conversion can be entered so that an analog signal connected to the gauge can be read in appropriate units.
The gauge has bi-directional controls allowing for manual control of the low and high speed fans, CASE relearn and ECU reset on GM vehicles, and on most Chrysler vehicles the transmission controller can be reset and Electronic Stability Program can also be completely turned off to improve track performance.
New optional relay output module allows you to control a 12v relay based on values of OBD2 or analog input data.
Last but not least, the Interceptor will measure 0-60 times, as well as 1/8 and 1/4 mile time and speeds. This is accomplished through a simple menu selection. This function is not available on the ISO based (older imports) due to slower bus speeds.
Installation is accomplished by simply plugging the supplied connector into the OBD2 port below the steering wheel. Literally plug-and-play!
Purchase Aeroforce Interceptor Gauge
