car wont start
Wisenos
Cleveland, Québec, Canada
even after all passlock reset tricks
the car wont start, so we took apart the covers and discovered a green/brown wire
this wire is "attached" to the ignition switch wire
any possible solution?
(( sorry if i'm in the wrong section lol ))
btw car is my brother's 4 door G5 "Pursuit"
the why we did this in first place it's because the key broke-in-half in the switch and as we managed to get it out that trouble happened
edit: would like an answer before we spend on a new ignition switch
and the car starts when we jump the starter (for 4-5 sec then stops)
Is the fuel pump coming on? It sounds to me like it isn't so check your fuel pump relay under the hood.
The way I diagnose things is by figuring out what the motor is not getting.
Any gasoline engine needs 3 things:spark, fuel, air
Figure out which one it's not getting and you will have a path to figure out whats wrong from there.
Wisenos
a thing i forgot to mention is: we tried to took out the ignition "barrel" to be able to take out the key piece in it and might broke something
