Not reaching full boost
After welding it yeah, any warranty you may of had is toast now.
hahn><boost
Im just thinking its going to be more flexible. thats what seems to be the problem, if the weld broke that fast.
hahn><boost
I went and got it TIG welded again. It was split in two spots this time. Seems to be holding up now. I also turned the boost down to 19psi, it was set at 25psi.
