About brakes.... reference
dsans11
I was going to replace my pads and rotors. Just was wondering if someone could tell me what size sockets (in advance) do I need to remove any necessary bolts to remove the brake pads and rotors for the front brakes. Thanks.
Intmd83r
New Hampshire
dont remember the size sorry but you will have little clips on the studs holding the rotor on . just bend a couple prongs and you can twist off and twist back on and reuse them . and pads might come with a shim . use it . If they dont save your old one. I got a set that didnt have a shim and would vibrate and sounded like crap . i was lucky and still had my old pads with the shim and no more problems .
