Instrument Panel
Drumrush
its pretty easy, pop ff the dash trim panels to the left and right of the steering wheel, 2 screws at the top of the bezel, and then a few screwes holding in the cluster itsself. and i have an ss cluster coming tomorrow, ill sell you my white 140mph g5 one for pretty cheap. it lights up red
bbrewbaker
Middletown, PA
Yeah maybe I'll take it. Do I have to recalibrate the speedometer, tach, and fuel gauges?
Nope the new one will work the same as the old.
Just plug and play. The millage is stored in the computer not the cluster.
A lot of us have swaped them.I'm one of them. I have a 2008 Cluster in my 2010.
ColbyJ
St. Louis, Missouri
While we're on the subject of the instrument cluster I have a question. As I scroll through my information of outside temp, oil percentage, etc. I noticed one that wasn't in my 2006 sedan. It says some number (usually this number bounces around as I drive) and then MPG INST. Can anyone tell me what this means?
Thanks,
Colby J (aka Amy)
Thanks,
Colby J (aka Amy)
Miles Per Gallon Instantaneous. Wasn't in the 05-06 cars.
Instant MPG is just about as useful as a screen door on a submarine. It never reads accurately, even at steady speeds
It's actually quite accurate, it goes off the injectors, throttle position, engine load %, and other factors to determine that number. Thus why it jumps around.
Thank you so much! It's been driving me nuts trying to figure it out! So basically it tells me the MPG I'm getting right that second?
Yep
