lowest drop?
SlvrSport
WV
ive been looking to get eibach sportlines for my 2008 sport sedan, I want to get the lowest drop for the buck.
is there anything that goes lower or coilovers for a good price? ive searched everywhere
1AJeremyD
Mass/NH
If you are just looking for a drop, SSC springs are decent for what you probably want. If you are really looking to get that flush look, you would want to go the extra mile and get a set of coil overs (Stance, KW, or Ksport are the most popular ones). The sportlines are pretty low but a lot of people run into problems with the spring actually cracking and getting them warrantied out through eibach.
If you want low check out H&R Race springs or B&G. The above idea is also good.
Keep in mind that when going that low you will start having issues with CV joints dying.
SlvrSport
WV
so in other words where my car is the sport and basically the ss minus the supercharger in 08, I should look for coilovers or springs for an ss?
I'm on springs on my SS and I have a 2 for gap fro wheel to fender
Sent from my DROID RAZR HD using Tapatalk 2
Sportlines are low, if you want more low check b&g, h&r, ssc or a set of coilovers.
Your 08 Sport should have the 2.4L motor with VVT and fe3 suspension.
