2007 cobalt won't start but has power , starts clicks but won't crank car , accessories are on fine
vmanatsa
Cobalt won't start. But has power won't crank please help
Does this intermittently
Trazy2017
Wi
Clean connections at starter, also ground connections for ecu, under front radiator hose connects to engine
todd foreman
frazeysburg
it may be timing chain issues pull valve cover check and see if there is slack in chain if so that's the problem or cam positioning sensors .
