For Sale 2007 cobalt ss/sc with blown engine
emperorjj1
Salem, OR
Engine has 135270 miles on it, no compression in cylinder 4. Car is in Salem Oregon updated mod list below
Stock Options:
Laser Blue Metallic
2.0 L Ecotec LSJ Supercharged
High Rise Wing
Non G85
Black Leather Interior
Sunroof
- Second Owner-
Engine/Drivetrain:
Harrop TVS 1320 Supercharger
2.8" Pulley
Badmab Header
SMG Motoring 2.5" Downpipe
Corsa 2.5" Touring Catback
LNF Shifter Bracket
GMPP LSJ Clutch Upgrade
Upgraded Axles
GMPP Option B
SMG Motoring Dual Pass Endplate
SMG Motoring Front Mount Heat Exchanger
NGK BKR7E Plugs
RAW 3" Intake
K&N Oiled Filter
TTR Motor Mount
TTR Transmission Mount Inserts
ZZP Boost Referenced Fuel Pressure Regulator
Snow Performance Stage 2 Water/Methanol Injection with 2.5 Gallon Trunk Mount Setup (Boost Referenced)
Dynojet Tuned 315whp 275 wtq
Suspension:
H&R Sport Springs
Koni Yellow Adjustable Struts (F&R)
Powell Raceshop XXX Rear Swaybar
Powell Raceshop S-CABs
RAW Strut Bar
Powell Raceshop Steering Rack Spacers
Moog Strut Mounts
Moog Swaybar Endlinks
Powell Under Car Rails
Wheels/Tires/Brakes:
Stock Polished LSJ 18's
R1 Premium Cross Drilled Rotors
Posi-quiet Pads
Exterior:
MPX SS Style Carbon Fiber Hood with color matched sides
MPX Shorty Antenna
LED 3rd Brake Light
Color matched Projector headlights with 2 TRS bi-xenon 5k mini H1 retrofits, V3(?) vled Triton turn signals
TRS 5k Foglights
Colodude custom passat turn and brake with running light rings in the inner and outer tail lights
Tint
G2 Paint LBM Vin Matched Calipers (3 of 4)
Under-body sprayed with second skin spectrum to protect against rust
Interior:
Recaro front seats, Black leather rear seats
Genuine Saab Solid Shifter Bushings
24designs Transformer Steering wheel badge
CA Dual Pillar Pod Color Matched
CA Steering Column Pod
Aeroforce Interceptor Scan Gauge (red)
AEM Wideband Air/Fuel Gauge
OEM SS Turborcharged Boost Gauage
Carbon Fiber Dash Trim & color matched Dash trim
Color Matched Door Trim/Steering Wheel Trim
Audio:
Pioneer X9110bt Screen DVD/CD/Navigation/Blue tooth
Currently has a 5 channel amp I was installing. Will include if the price is right or wire to have audio for a little less.
Engine Dress Up:
Laser Blue Metallic Valve Cover
Powell Raceshop Wrinkle Black Coilpack Cover
I'm not really sure what a car in this condition would go for and since a price must be listed asking 3500 OBO
full
full
full
full
full
emperorjj1
Salem, OR
yeah if i was in a better situation i would probably have started parting out already. My apt building is a bit restrictive
