09 cobalt bogs down, stalls, bad fuel economy
al3xjc
pennsylvania
I have an 09 cobalt LS, my car is throwing P3000 (CAN data bus, instrumentation - glow plug warning), P0401 (Exhaust Gas recirculation flow insufficient), and a P0128 (Coolant Thermostat, temp below regulating temp) Just repaired a very cracked flex pipe and o2 sensors. When "cold" started it will sometimes stall out, if I clear the codes the RPM's will bounce from 900 down then back up a few times and catch itself but will sometimes just stall out instead of catching itself. I also use to get 30 MPG now get 18! ANY help or ideas is appreciated! Thanks!
BGreen
california
Stuck open EGR valve? I've been told if it stuck open it could cause bad idle and mpg drops.
