06 ion 3 won't starr
tuenerb
I have an 06 saturn ion 3 that will not start. I had the issues where it wouldn't start in the cold. I did the white wire fix and it worked for 3 years. The battery blew up and I put a new one in and it was fine. At this point it wouldn't always start the 1st try sometimes. I had to turn the key back a few times. One day drove it home and went to get back in and it wouldn't start. Checked the starter and relay. Replaced the ignition switch and did the reset and nothing. I thought it was the security system so I bought a module to put in the bcm to over ride it and nothing. It did reset the security and the light no longer flashes on the dash. Everything works besides it not starting or even trying to. The only thing happening is pwr steering and coolant comes up flashing. On the little screen. What could this be? !?
ThoR294
Did you check the starter? Possibly a bad winding causing it to randomly not start
