2005 Pontiac Pursuit Remote Starter
Curtis
Hi I just bought a remote starter and a bypass unit. I am wondering if I can get some advice on how to install the remote starter and the bypass on a 2005 Pontiac Pursuit. Has anyone ever installed a remote starter on there Cobalt?
These are the products I bought.
Remote starter module:
http://www.bestbuy.com/site/compusta...9#tab=overview
Bypass Unit:
http://www.xpresskit.com/product.aspx?productid=240
Remote:
http://www.compustar.com/remotes/RF-1WG5-SS-bundle.php
Now the part I dont quite understand is when I look at my ignition switch wiring I dont have a orange or blue wire coming from the ignition to the BCM like in the diagram on page 3.
The diagram can be downloaded here: http://www.xpresskit.com/product.aspx?productid=240
Wires to the ignition switch:
wire 1: Black and White
wire 2: White
wire 3: Brown
wire 4: Yellow
wire 5: Red and White
Here's the connector data from GM. Cobalt is a Passlock 3 system though IIRC.
GM Service Books said:
1 -- -- Not Used
2 ReD/WHite Battery Positive Voltage
3 YEllow Run/Crank Relay Coil Control
4 BrowN Accessory Voltage
5 WHite Off/Run/Crank Voltage
6 WHite/BlacK Ignition Key Resistor Signal
