95 plymouth voyager
Firebalt07
Tyler TX
my grandparents have a 95 plymouth voyager. the windshield wipers wont work. i tested the wires at the motor and nothing. tested the connections at the fuse and nothing. now this car has electrical issues anyway, but i am trying to find a way to manually rewire the wipers to some kind of other switch. so i dont have to worry about the already faulty wiring... any ideas...? thnx
UncleDave
High in Colorado, in a Valley
You might be best off, if you can trace down the origional problem rather than bypassing it.
I had an early Voyager. Had two basic problems One was that two connections in the Voltage Regulator were not soldered. The second one took me 90K miles to solve. There was crud in the fuel tank that kept clogging the filter inside the Fuel tank. It is a cluster of the Gauge Sender unit, Fuel Pump. Before the pump is a sock type of filter. I cut this filter and put a OIL BURNER in the fuel line.
Bluntly. If a second problem comes up. Then trouble shooting can be compounded.
