Abs issues
e.nigma
I have a 2 part question. 1, does the ABS module have to be paired to the BCM? 2, anyone have a picture of the pinout of the connector for the module. I'm trying to check the circuit to the RF sensor . but can't find the correct wires for on the ABS connector.
I don't believe the ABS module needs to be paired, should just be the BCM and ECU.
What year/trim?
e.nigma
What year/trim?
OK I'm a dumbass, apparantly. 2007. C0040. Checked the wheel sensor, it has continuity, approx 1500ohms. Wanted to check wiring for breaks, but the colors at the module don't match the colors at the steering knuckle connector.
