check engine code p0449
tasman
I have a 2005 cobalt lt with a 2.2 auto and have a code P0449. Any ideas on a fix???
DTC P0449 Evaporative Emission (EVAP) Vent Solenoid Control Circuit
The Evap canister vent valve is located on the canister itself under your car just in front of the fuel tank. #26 in the picture.
Check the wiring associated with it, and that everything is plugged in tight. Might just need replaced.
tasman
2005 Cobalt EVAP sensor code P0449
I replaced the sensor with a used one that has no check engine light on it and the light still comes back. The plug and wiring look good and I have power to the red wire but get nothing in the white wire to the sensor. Not a ground or power with the key off, key on or the engine running. Both sensors were the same. Any other ideas??
