dimming lights
During the day? Guessing your autolights are turning on and off.
newfiedan
SK, Canada
drains
well that depends on the setup you have, do you have any subs in it, or additional lighting things which could cause a higher draw at times? In a dimming light situation here are the basics to check;
1) battery condition, is it holding a charge
2) alternator output (with the battery in the trunk and that piddly little charge wire it hurts the electrical performance of the car a bit)
3) Are all connections tight and clean at the battery and ground.
RedDead
Princeton, West Virginia
it's just straight stock right now...that's why i want to fix it now b4 i do everything ...it has done it the whole time i have had the car day and night.....i'll check the basics and get back at you guys....thanks
