Engine power reduced/engine disabled
Shadow9198
Alberta
Hey guys, so I'm having an issue with my 2006 cobalt coupe 5 speed 2.2L. While driving it will sometimes come up with the engine power reduced and engine disabled messages on the speedo screen. When this is on I cannot even crank it. If I walk away for a while and come back, it will fire right up and drive like there is nothing wrong. I never have had a scan tool on me when the issue happened, but when I got it running this last time I took it to my shop and hooked up my scan tool to retrieve any history code . The only code for concern that I pulled up was a P0341, which calls for a problem with the cam sensor. Only problem though is that everything I have read tells me that 06 and under 2.2 do not have a cam sensor, so now I'm lost on what it could be. Any help would be appreciated thanks.
