found a supercharger wondering if it would fit
no the sc on the pontiac is an m90 not a m62 it will fit but its not ideall because that pontiac is a 3800 series that a 3.8l the m62 was designed for a lower displacement cars
---------- Post added at 01:43 AM ---------- Previous post was at 01:43 AM ----------
if you go to the build section see my build its got everything you need
Think you'd need a custom intake manifold or manifold adapter but it should work just fine once you throw some money at it.
it would also be more than the stock internals can handle the buick gsx and the pontiac gtp stock push over 260 hp
Just either get a bigger pully or have more of it going out the bypass valve to achieve less psi.
gberland
Canada , Alberta
so basically the M62 would fit an 2.2L application?? i just assumed they only fit the 2.0L ?? just wondering
