Fuel Pump/Sensor Access Door
ckavanaugh
Milwaukee
Hello. I am trying to replace the fuel tank pressure sensor on my 2006 Cobalt LS. The sensor itself is located on the top of the fuel tank next to the fuel pump. From what I understand, there is an access door underneath the rear seat. I removed the rear seat but cant see any noticeable access door that would lead to the fuel tank pressure sensor. The only panel I can discern is on the passenger side of the rear seat with a cable leading to it. Unfortunately this panel is rather small and difficult to remove. Is this the panel that would lead to the fuel pump/pressure sensor? Thanks in advance for the help on this one.
There isn't a panel for accessing the fuel tank from above. Have to drop the tank from below.
