garrett manifold
USMCFieldMP
Findlay, Ohio
Have you looked at the Vulcan Log Manifold? It would work for you... and it isn't cast either.
www.VulcanTurbo.com
Either way, make sure that you DEI Exhaust Wrap the manifold... it'll put more heat into the Turbo which will help with spool, and it'll keep some heat out of the engine bay, which will help quite a few things.
BlackCobalt707
Dover AFB, Delaware
i got some heat wrap sittin in my garage waitin to go on the turbo and manifold. i did check vulcan, and i checked the RD Fabs folks you was talkin about but they was all way outta my price range, but i figure garrett should suit me fine. how effective is that heat sprayin stuff? i wanted to spray that and use heat wrap as well
