Good shocks
fender81
Chandler, AZ
What are some suggestions on some good shocks and struts? I also want to lower my car with possibly some Eibach Sportline springs. Thanks.
if you have a base model you can get a good deal on the SS models shocks and struts at www.cradeenginedepot.com. they are interchangeable and the eibach springs will fit.
or forget them both and buy coilovers this is the more expensive route
fender81
Chandler, AZ
Thanks, I actually went the coilover route. I bought some BC coilovers. I have read really good reviews about them. Do you know of any issues after lowering the car, besides possible scraping?
CV joints, if you are going really low a lot of people end up breaking their CV joints, OTTP, TTR, and Powell motorsports make rotated transmission mounts so the axles are in proper alignment again. Oh and bumpsteer, rack spacers will fix that problem.
fender81
Chandler, AZ
Thanks. I don't think I'm gonna go that low. Right now I'm sitting at the BC coilover preset height. It dropped my car about 1.5 inches or so. I would say I have about 1 to 2 inches of clearance above the wheels to the bottom of the wheel well (outside metal part) right now. I don't know if that's what you consider extreme or not. Right now the axles are sitting pretty much straight out so I don't know if that is too much for the CV joints to handle. I don't seem to get bump steer right now.
If you sit at that height you should be fine, just keep an eye on your axle angle, the coils will likely settle.
fender81
Chandler, AZ
Ok, thanks. I'll keep an eye on it. If I decided to install rotated tranny mounts, how easy are they to install and do they come with instructions? Should I also go ahead and get stronger axles? What sort of an axle angle should I start worrying at?
Its more of how far the springs compress, if the axles move to extremities a lot the CV joints wont last as long, the straighter the better.
CFCobalt
the matrix
i actually should upgrade my shocks/struts here pretty soon.....good info guys...thanks :)
