Hit large rubber object on hiway now dead no fuel check engine light flashing
Ta2edtexan
London Tx
i hit a big solid piece of rubber the other day and since then my car wont start i hit it good but it wasnt as bad as i had braced for when i figured out it was going to happen.. the car died immediately and now it wont start. there wasnt any real damage a small portion of the bottom of the radiator has a small dent in it but it was on the lower outside lip of the bottom and very small not affecting the radiator performance.. then you can se where it cleaned the oil pan and the rest of the way down where it shined everythign up there is a small dent on the fuel tank shield but its not deep enough tio have contacted the tank under... i have torn apart my entire interior looking for a cut off switch or something.. under the car i see no way any wires got damages as its on the right center part of the car and nothing is there all the way back... the engine light flashes and the motor cranks... nothing else happens anty ideas . I already have scoured the carinside and out... if theres a klill switch there those engeneers should work for the cartel cause it is in a really good hiding spot
You should check all your fuses, particularly the one for the fuel pump.
Ta2edtexan
London Tx
ive checked them all ive checked all the wires i was stuck on the side of the road in my car for 6 days with no phone and in a n area that saw little traffic
Ta2edtexan
London Tx
i had alot of time to go over things i have the entire interior pulled out and lots of the rest of the car too
Wow....that sucks. Well if the wiring, relays, and fuses are all good that just leaves the pump. Drop the tank and see if direct powering it kicks the pump on.
Staff online
