How To- Wet Sand Paint
Step 1
Allow new paint to dry at least 24 hours before wet sanding, though the time will vary depending on temperature, humidity levels and how many coats of paint were applied. Simply, just be sure the paint is good and dry before wet sanding.
Step 2
Set up your materials. The 1000 grit sand paper, which is the coarsest you should ever use, 1500 and 2000 grit is more advised unless you have serious runs that need the 1000 grit, along with a flexible sanding block and dish pail of water. A drop of dish soap has been added to the water to help keep it slick. Be sure you have your misting spray bottle ready and that you have good lighting set up.
Step 3
Mist the surface you are about to sand with plenty of water. Start with a small area of maybe 12 x 12 inches till you get the feel for this. Wrap your sand paper over the sanding block and dip it into your water pail getting it nice and wet. Work the 1000 grit with light pressure over any prominent flaws in a level smooth motion, dipping your block and misting the surface often, keeping it wet at all times. To see where you are at wipe the area dry with your soft rag and work your way to finer grits of 1500 for instance, or even 2000 for final sanding over the entire area after flaws have been removed with the coarser 1000 grit which is most likely to leave sanding marks.
Always work with the block and avoid using finger pressure without the block unless you are forced to around tight spots where the block won't fit. Avoid sanding on contours or edges of the car, it is "very" easy to remove the paint completely. Use extremely light pressure on these areas if you must touch them at all.
Step 4
After your surface is nice and smooth from your wet sanding you will need to apply a fine rubbing compound to bring the paint color back. Compound also serves to flatten out paint that may have been missed by wet sanding. Work with the compound until your paint is nice and flat and has it's shine back.
Step 5
After you are satisfied with the look and feel from the rubbing compound you are ready for clear coat or silicone free glaze. You will need to be sure that the surface is thoroughly washed clean from any rubbing compound or dusts that may remain if you are applying clear coat. Follow any specific directions by manufacturer before applying clear coat​
06_ion2
Banned
Lino Lakes MN
i wetsand painted cars after 45min in the oven and 2 hours in the sun. wetsand with 2000 grit and go over it again with some 3000 to get alot of the fine scraches out. makes it way easyer to buff if wetsanded with 3000 at the end.
