OTTP Rotated Mounts Comparison VS. TTR S.T.O.P Mounts
Status
Not open for further replies.
ls1fbody
Quoted From the Legend Himself.
qwikredline said:
THE 0TTP ROTATED MOUNT COMPARED TO THE TTR STOP MOUNT.
The first thing to do when we received the TTR mounts, was to review the literature: here we go:
Turbo Tech Racing STOP Transmission Mounts.
Which stands for: "Strategically Torque Optimized Positioner Mounts”
These mounts are Strategically designed to have a Torque Optimized Position. They will reduce engine movement, due to the firmer bushings (Optimized), and also align the axles (Positioner); increase the torque transfer to the wheels.
More Information:
1. Firmer bushings/less wheel hop/more torque transfer
2. Works with the Turbo Tech Racing Upper Engine Mount
3. No "inserts" to press in, come full assembled, direct bolt in
4. No "stage" kits to buy, these fully position your Cobalt
5. Made in the USA @ Turbo Tech Racing, LLC
6. Strong light-weight aircraft grade 6061-T6 aluminum
7. Engraved with the “TTR” logo (Shown in Photo's)
8. Comes with a full color install sheet
9. Quality of Turbo Tech Racing is known to be the best
10. Closer bolt to sleeve hole diameter, for a closer precision mount. We do not use a generic bushing; it is custom/specific to this mount, unlike other companies who use off the shelf bushing/sleeves.
11. Choice of Red or Black Bushings
12. Alignment was done in house using a state of the art CMM (Coordinate Measuring Machine) (Faro Brand)
These have been track tested on many Cobalts already, ranging up to over 400+ HP! For references please let us know.
Fits:
2005-07 Chevrolet Cobalt SS/SC 2.0L, F35 Trans
2008-10 Chevrolet Cobalt SS/TC 2.0L, F35 Trans
List Price: $399.99
Price: $279.99
0TTP say:
These new mounts rotate the engine and trans to align the axles. This does two things, it eliminates wheel hop and it helps your axles/trans case survive. Unlike poly mounts these are far less harsh and will have less vibrations. These are made from Billet 6061 aluminum and cnc machined You will have 2 options when ordering.
Stage 1 Use's a Billet rotated front mount with a spacer under the stock rear mount. This is for sub 300whp cars. There will be very little vibration from the mounts.
Stage 2 Use's Billet front and back rotated mounts and the spacer is built into the rear mount. This is for the avid drag racer, these will have slightly more vibration then stock but nothing close to poly. Stage 2 will also help get more power to the ground, due to the mounts limiting engine movement.
Billet mounts are only for 05 and up cars. If you have an 04 please contact us as you will have a core charge on your front mount, a little longer wait period and the pricing is different.
Made by Powell RaceShop for 0ver The Top Performance.
List Price: $265.00
Price: $205.
Stage 2 add 125.00= $330.00
Now lets open the box and review the mounts:
TTR, attractively powder coated black with Red Poly insert and powder coated center alloy bushing.
0TTP attractively machined natural aluminum with a jacketed rubber voided insert, and two alloy spacers
The picture here does not have the insert pressed in
The next thing we did was compare the center line of the bushings of the two brands of mounts compared to each other. It is well documented that the 0TTP ones came out first. The TTR ones are not identical probably a couple of millimetres off. Dont think it makes much of a difference.
Next step was to determine what they are made of. Both subjected to a material analysis by our friendly scrap yard guy with hand held tool. (next month we will send out all the comparative parts we have to the lab., for non destructive materials analysis. Both brands of mounts are 98+% alloy and 1+% iron.
Best guess: 6061 grade alloy.
Next step was to look closely at the machining, at the drilled and tapped holes of the rear mount and for the TTR mount remove the powder coat a bit more. The two mounts are different, the threaded holes are dull in the TTR mount, not shiny like the competition. Wgat does it mean? Well we put the little tab at the bottom of the rear mount in the vice , clamped and pushed.
TTR mount snapped the tab!
The 0TTP mount spread the jaws in the vice, the tab did not break!
The 0TTP mount is damaged but not broken:
We gotta figure this out. Drilled the material:
We got a similar sized piece of 6061 3.16 material about a ¼ inch wide and put that in the vice . Note the broken tab on the vice beside:
Stuck an adjustable wrench on the tab for leverage and pushed:
Bends but does not break.
Conclusion: The TTR mounts are (sand?) cast aluminum to a shape, and then machined. We know the 0TTP mounts are machined from a solid block of T6061 alloy. Casting makes the material more brittle than machined blocks of alloy. Does it make a difference for strength? Considering the overall mass of the TTR mount, maybe nnot. For weight: Well for sure the TTR mount is very heavy by comparison, even to the OEM mount which is of similar size.
TTR Rear
TTR front
0TTP front
The bottom line to all this? 2.4/ 2.9 lbs for the TTR mount and 1.2/1.4 lbs for the 0TTP mount. The machined billet from Josh and Sean is half the weight of the machined cast TTR mount.
The discussion of a voided bushing as a center compared to Poly is easy. A Poly mount transmits vibration more than a voided bushing which itself is designed to support but isolate vibration. The poly in the TTR mount a very nice deep red color, but is not uniform in finish however, and may have been made locally. Poly is sensitive to humidity when being poured, this may have happened to these mounts.
The center bushing in the TTR mount is a band saw cut sleeve, not very well finished or consistent in width mount to mount. The 0TTP bushings are machine cut on a lathe and well finished to a precise size, every spacer is identical in width..
Look closely at this picture you can see the rough cut center sleeve.
In conclusion you make your own choices.
A good question is “ where are the TTR mounts cast? It looks like a sand casting. Was it done off shore? In which case the statement “made in the USA” is perhaps not accurate.
The 0TTP mounts are 100% not made in the USA. They aare made in Canada. The alloy comes from the same smelter that produces alloy for the GM LS engines. In fact all LS engine castings are made in Canada.
At the end of the day, review the prices of the mounts and decide for yourself the quality, weight, function, NVH and durability you wish.
hmmmm maybe i can have my stuff shipped from Powell instead of OTTP to save on shipping, :) that would be kewl, i could spend more money on parts this way lol
Ive got those towhooks in the mail right now straight from PMS....just realized it spelled that lmao!
ls1fbody
You got the towhooks from him because he does not sell them through OTTP.
He has an agreement with OTTP to sell the rotated mounts exclusively through them.
Order from www.ottperformance.com
1WhiteSSTC
Banned
The Great White North
I will be ordering thru OTTP yes but I am hoping they can have the parts sent from Powell instead of going across the boarder, it makes more sense this way, i sure as hell dun wanna pay for duty fee's and shit.
---------- Post added at 08:10 PM ---------- Previous post was at 08:10 PM ----------
good thing i have no need for mounts
OTTP>your mount :p cmon upgrade man
Status
