PIP: MU3 Manual Transmission Hard Shifting
rukkee
WNY
Service Information
2009 Chevrolet Cobalt | Cobalt, G5 (VIN A) Service Manual | Preliminary Information | Document ID: 2273389
#PIP4638: Dificult To Shift Or Unable To Select All Gears - keywords shifter - (May 6, 2009)
Subject: Difficult To Shift Or Unable To Select All Gears
Models: 2008-2010 Chevrolet Cobalt SS, HHR SS
Equipped With RPO MU3 Manual Transmission
Condition/Concern:
Customers may comment that the transmission is difficult to shift and or it cannot be shifted into all gears. This condition may be caused by a locator pin left in place (see photo below) that was meant to be removed at the assembly plant or a shift cable out of position.
Recommendation/Instructions:
Inspect the transmission and shift linkage if the locator pin is still in place remove the pin and discard, retest transmission operation. If the pin is not found in position inspect the shift cables for being properly seated in the cable bracket, if the cables are out of the bracket reseat the cable or cables and test operation. If neither of the above conditions are found follow SI to properly diagnose the transmission shifting concern. Also reference the latest version of PIC4992 to aid in hard to shift concerns.
