Save gas and money with Fuel-Efficient Tires on - CARiD List
carid
Vendor
Cranbury, NJ
To save on gas, manufacturers develop various solutions, such as the hybrid powertrains, lightweight materials, cutting aerodynamics, The majority of modern hybrid and electric cars are equipped with Fuel-efficient tires, to maximize the range, but such tires also work in the same way for regular cars with internal combustion engines.
They are designed to reduce energy loss when accelerating and decelerating thanks to the low rolling resistance. Switching to low rolling resistance tires can improve fuel mileage by as much as 1-2 miles per gallon. If this is an improvement you're looking for, check the most popular fuel-efficient tires available at CARiD.
#1 Ecopia EP422 Plus
https://www.carid.com/bridgestone-tires/ecopia-ep422-plus-34950407.html
Features:
- Improved wet traction and hydroplaning resistance
- Made from ground-up post consumer tires
- Increased fuel efficiency
- All-season performance
#2 Continental True Contact Tires
https://www.carid.com/continental-tires/truecontact-33290390.html
Features:
- High-speed rating and load index for extra safety on the road
- Precisely engineered traction grooves for better wet traction
- Made using ComfortRide technology for a perfect balance between comfort and performance
- Specially formulated tread compounds for extended tread wear
#3 Firestone Affinity Touring
https://www.carid.com/firestone-tires/affinity-touring-1075348.html
Features:
- Optimized tread pattern delivers a quiet, comfortable ride
- Advanced silica tread compound improves traction in wet conditions
- Diagonal and lateral sipes ensure excellent traction in snow
- Long-lasting tread compound
#4 Goodyear Eagle LS2
https://www.carid.com/goodyear-tires/eagle-ls-2-487207.html
Features:
- Efficient water evacuation
- Enhanced handling and traction with reduced tread noise
- Contemporary appearance
- Long tread life
#5 Kumho Solus TA11
https://www.carid.com/kumho-tires/solus-ta11-58442175.html
Features:
- Engineered for class-leading comfort and shock absorption with Kumho's exclusive Escot casing
- Excellent fuel economy and a long tread life the result of a dual silicone compound engineered to cool quickly. It runs colder, lasts longer, and improves fuel efficiency
- Exceptional grip and stability in heavy rain and snow. Four, deep center grooves channel water away quickly
- Engineered for traction on ice, with tiny waffle sipes creating thousands of small gripping edges
