Secondary Air Injection System Pressure Sensor
Serion18
This is On my 2007 LT with the 2.4.
I had a code for my MAF sensor, so I replaced that and cleared the code. Now I have the code P2341 which is my Secondary Air Injection System Pressure Sensor. Is this something that can be cleaned to get rid of the code or do I have to replace it?
Are you sure that's the code? Also that trim didn't come with a 2.4, the LT only came with the 2.2.
There's a P2431 for the SAI system.
Briefly looking over the DTC diagnostics, it looks like it could be the air pump, air solenoid valve, air solenoid, one of the hoses, or the control module.
There are a couple things you can check with just a volt meter.
Serion18
So I unplugged the sensors and they had moisture in them. Could that have been the issue?
