"Secret " TSB : Timing chain
rukkee
WNY
I stumbled across this the other day after not seeing it for years . Freek on css.net found this a long time ago and posted it ...all credit is his . GM has since removed it from Dealerworld.
AIP3252
MODELS:
206-2007 CHEVROLET COBALT, COBALT SS
2006-2007 CHEVROLET HHR
2006-2007 CHEVROLET MALIBU
2007 PONTIAC G5
2006-2007 PONTIAC G6
2006 PONTIAC PURSUIT(CANADA ONLY)
2006-2007 PONTIAC SOLSTICE
2006-2007 SATURN ION REDLINE
2007 SATURN SKY
BUILT BETWEEN 4/1/06 - 11/1/06
WITH ANY OF THE FOLLOWING ENGINES
2.0 ENGINE (VIN P - RPO LSJ)
2.2 ENGINE (VIN D OR F - RPO L61)
2.4 ENGINE (VIN B OR P - RPO LE5)
CONDITION/CONCERN:
On rare occasions, a tick or rattle noise may be heard from behind the front cover of the engine and/or pieces of a timing chain roller may be found during an oil change. This may be the result of a timing chain concern.
Non-heat treated timing chain rollers were randomly installed in the assembly line hoppers. He advised that this happened sometime between 4/1/06 - 11/1/06 so it can randomly affect late 2006 - early 2007 models.
RECOMMENDATION/INSTRUCTIONS:
If this concern is experienced, inspect the timing chain for missing or damaged timing chain rollers. If a missing or damaged timing chain roller is found, replace the timing chain and gears using the part numbers currently listed in the parts catalog.
ff_drift_lol
long island, new york
ah shit i've been looking for this! you say it was deleted from dealer world? that's funny cause i often find myself wondering why there's tons of ecotecs and lambda crossovers coming into the shop for timing chains and no tsb or recall!
ff_drift_lol
nooope, this is what you hear all the techs complaining about when theyre doing timing chains. the tensioner failing will just make the chain tighter and more vulnerable to stretching eventually breaking.
chevysales
AIP3252
MODELS:
2007 PONTIAC G5
2007 SATURN SKY
CONDITION/CONCERN:
you may want to learn an updated search on dealerworld. it isn't hidden but has revised #.
users with no business on dealerworld is one of the reasons we have to change our password so often. developing a relationship with your local dealer may make it easier for you to find TSB's as there *shouldn't" be a reason any dealer hides them if asked by a customer.
every car that comes in for service should have a VIS run so any outstanding TSB/TI's, etc should show up if you go to a competent dealer.
