strange clutch replacement
SageMoonblade
Michigan
So I recently replaced the clutch on a very base model 09 cobalt. Upon getting the car back together the fuel gauge that was over 3/4 of a tank now reads empty, the left and right stick movement seems very stiff, and the biggest issue, it won't start. It won't even turn over. I tried reprogramming the keys with the 3 10 method, tried jumping it, finally I bypassed the cranking relay and it will crank over that way but seems to have no spark. This one has,me confused, the rest of the job went rather smooth. Not sure if they are one big issue or several. Everything else seems to work fine and the cranking relay itself tested good.
