Tire Pressure Monitor Sensor Problem Resolved
LSCobalt
Nashville, TN
Thanks to all who replied. I went ahead and ordered the Standard Motors Products TMP45RA sensor from Rock Auto. The sensor arrived today and I picked it up and drove to the auto repair shop. I let the guys there remove my tires from the rims and put the tires back on the rims. They charge me $20 for this. With the tire removed from the rim, I drove home and removed the old sensor. I unscrewed the sensor body from the stem and then pulled the stem off the rim. This took less than 5 minutes. I removed the valve from the new sensor stem and pulled the stem and sensor onto the rim. I drove back to the shop and the guy put the tire back on the rim. I drove home and relearned all four tires.
The yellow tire icon is off and all four tires are displaying 30 psi or so. I suspect the right front tire sensor is failing so I will probably have to do all this again. The total cost was $47.50.
I forgot to mention that the original sensor is a Schrader.
five7man
five7man
The battery in TPMS die and that what fails the sensor.
If the battery is going dead in one sensor, the rest of the sensors probably have dying batteries too.
I find it best to bite the bullet and replace them all at the same time.
On a side note, I played the replace the one TPMS sensor at a time as they failed game on my wife's 2008 Trailblazer, what a pain in the a$$ doing it that way.
It was about 6 months of hearing the "check tire pressure" message is on again complaint again and again and again.
Finally just replaced them all and haven't had a problem since.
