TSB: Getrag M86 or MG3 Shifter Roll Pin
rukkee
WNY
Service Information
Document ID: 2313666
#PIP4674: Blocked Shift Gear Hop Out 1st 3rd 5th Gear Or Dificulty Shifting - (Jul 21, 2009)
Subject: Blocked Shift, Gear Hop Out, 1st, 3rd, 5th Gear Or Difficulty Shifting
Models: 2005-2010 Chevrolet Cobalt
2006-2010 Chevrolet HHR
2005-2009 Pontiac G5, Pursuit
2003-2007 Saturn Ion
2004-2007 Saturn VUE
Equipped With A Getrag Manual Transmission RPO M86 Or MG3
Condition/Concern:
Some customers may comment about hop-out or blocked shift of 1st, 3rd and 5th gears or difficulty shifting the above listed manual transmissions. The shift lever roll pin can back out and contact the shift cover during a shift event. This can cause an incomplete, blocked shift or difficulty shifting the transmission. See photos, the first two are of a dislodged roll pin and the last two are of a correctly installed roll pin.
Recommendation/Instructions:
Prior to any internal transmission repairs inspect the shift cover and lever to see if the roll pin has backed out and is dragging on or contacting the housing. If roll pin contact is evident then the shifting difficulty may NOT be an internal transmission concern.
If the shift cover shows witness marks from contact with the roll pin, dealers should replace the complete shift cover assembly, item #1 as shown in SI document #881811.
Important: Do not replace the transmission for this concern.
If the roll pin is not dislodged follow published SI diagnostics.
