TSB :LNF Charge Pipes
rukkee
WNY
Service Information 2008 Chevrolet Cobalt | Cobalt, G5 (VIN A) Service Manual | Document ID: 2195686
#PIP4485: Low Boost, Reduced Power and/or DTC - keywords air cac charge control cooler driveability ecm engine gas hole lnf low maf mil P0101 P0299 P2178 pipe power reduced reducdpwrmde rub ses start stall - (Sep 26, 2008)
Subject: Low Boost, Reduced Power and/or DTC
Models: 2008-2009 Chevrolet Cobalt SS Only
Condition/Concern:
If a technician encounters a low boost/power condition and/or dtc, the following may help.
Recommendation/Instructions:
When a technician encounters a low boost/power condition and/or related dtc on a 2008-09 Cobalt SS they should inspect the right side CAC-(Charge Air Cooler) pipe for contacting a radiator support bolt. Due to the location of the CAC on 2008-09 Chevrolet Cobalts a radiator support bracket bolt on the right front may make contact with the lower charge air cooler/hose from below. This contact may cause the CAC to leak boost or vacuum if a hole is present. Review the illustration to see the location of the suspect bolt. A thick washer may be added to the bolt to increase clearance.
Note: Bulletin 07-06-04-029 should be used to diagnose the charge air system when leaks are suspected. This bulletin may be aided by using the evap smoke cart to introduce smoke to the CAC system.
(1) Right lower radiator support bracket
(2) Right front lower Charge Air Duct concern
(3) This bolt will wear a hole in the Charge Air duct
