TSB: Noise From Rear Suspension
rukkee
WNY
Service Information
2009 Chevrolet Cobalt | Cobalt, G5 (VIN A) Service Manual | View All Bulletins | Document ID: 2445405
#06-03-09-005D: Squawk/Squeak Type Noise from Rear Suspension While Driving Over Bumps at Low Speeds (Replace Rear Suspension Insulators) - (Apr 15, 2010)
Subject: Squawk/Squeak Type Noise From Rear Suspension While Driving Over Bumps At Low Speeds (Replace Rear Suspension Insulators)
Models: 2005-2009 Chevrolet Cobalt
2005-2006 Pontiac Pursuit (Canada Only)
2007-2009 Pontiac G5
This bulletin is being revised to update the Parts Information. Please discard Corporate Bulletin Number 06-03-09-005C (Section 03 - Suspension).
Condition
Some customers may comment on a squawk or squeak type noise coming from the rear suspension. This noise typically occurs while driving over bumps at low speeds.
Cause
The cause of this noise may be the rear suspension insulators.
Correction
Replace the rear suspension insulators following the Control Arm Bushing (Suspension Insulator) Replacement procedure in SI.
Parts Information
Part Number
Description
Qty
20902798
Insulator, Rear Suspension (RPO FE1)
2
22729411
Insulator, Rear Suspension (RPO FE3, FE5 with LSJ Engine through 2008)
2
25782808
Insulator, Rear Suspension (RPO FE5 with LNF Engine, 2008-2010)
2
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
E4090
Insulator, Rear Suspension Support - Right - Replace
Use Published Labor Operation Time
E4091
Insulator, Rear Suspension Support - Left - Replace
© 2010 General Motors. All rights reserved.
