Service Information
Document ID: 2322970
#07-02-32-007B: Diagnostic Tips for Power Steering Inoperative/Steering Wheel Hard to Turn, Power Steering Message Displayed on DIC, DTCs C0176, C0475, C0476, C0550, U2105, U2107 Set - (Aug 6, 2009)
Subject: Diagnostic Tips for Power Steering Inoperative/Steering Wheel Hard to Turn, Power Steering Message Displayed on DIC, DTCs C0176, C0475, C0476, C0550, U2105, U2107 Set
Models: 2005-2010 Chevrolet Cobalt
2006-2010 Chevrolet HHR
2005-2006 Pontiac Pursuit (Canada Only)
2007-2009 Pontiac G5
2003-2007 Saturn ION
This bulletin is being revised to update the information for DTC C0475. Please discard Corporate Bulletin Number 07-02-32-007A (Section 02 -- Steering).
The following diagnostics might be helpful if the vehicle exhibits the condition(s) described above. Use the appropriate recommendation based on what symptom has occurred.
No DTCs
Review Corporate Bulletin Number 05-02-32-002D to assure you do not have a blown 60 amp steering fuse. The fuse can be blown during improper jump starting of the vehicle on the HHR and ION. Check for this particularly for tow in conditions. DO NOT replace the steering column unless an internal short has been identified in the column that is causing fuse to blow.
Power Steering Warning Message on DIC with DTCs C0176 and C0476
This condition is often the result of excessive lock-to-lock turns of the steering wheel, causing the thermal protection in the power steering control module (PSCM) to take the steering motor temporarily off line. This is a normal operating characteristic of the system. DO NOT replace the steering column for this condition. Refer to Corporate Bulletin Number 06-02-32-002C for additional information.
Power Steering Warning Message on DIC with DTC C0550 in the PSCM
Inspect the motor harness connection to the PSCM. If no connector problems are found, replace the steering column ONLY as this is an internal controller issue.
Power Steering Warning Message on DIC with DTC C0475 in the PSCM
Check the connection between the EPS motor and the power steering control module (PSCM) by ensuring the harness connector is properly seated. If the connection is normal, replace ONLY the EPS motor.
Note: If the DTC resets immediately following motor replacement, replace the steering column.
Power Steering Warning Message on DIC with DTC U2105 and/or U2107 in the PSCM with any other U codes
Although the code(s) appear in the PSCM, these are communication codes and are not the result of a problem with the column operation or the control module. If the codes are in history, clear the codes and re-key the vehicle a few times to see if they come back. If they reappear, look for a communication issue from the BCM U2107 or ECM U2105 (wiring, connector, etc.) as the root cause. If the codes do not reappear after a test drive, return the vehicle back to the customer. DO NOT replace the steering column.
Warranty Information
Labor Operation
Description
Labor Time
E8434
Power Steering Assist Motor Replacement
Use Published Labor Operation Time
E7680
Steering Column Replacement
© 2009 General Motors Corporation. All rights reserved
No DTCs
Labor Operation
Description
Labor Time
E8434
E7680
