doing a motor swap on a 2005 and 2006
noway
Louisville ky
I have a 2005 ls wrecked with 120k and new transmission. I have a 2006 lt blowed motor. Ive dun the swap and ran into some wiring problems has anyone came upon this. I really could use sum help....so im using the 2005 ls motor and trans (i dropped and swapped k memebers) in the 2006 lt.
Never done the swap, but 05 2.2 to 06 2.2 should be a straight swap as they didn't change anything.
noway
Louisville ky
A few plugs are not the same and im not sure of this but the big silver rectangle with 2 big plugs only 1will work. It mayb the ecm or the computer. I really dont know. Also a plug on 2005 only has 4 wires in the plug and the 2006 has 12 wires
You sure both of those are the 2.2? Pictures of the connectors that don't fit?
Are you swapping ECUs as well? What are the part numbers printed on both?
As for the two purple connectors, pretty sure there's a couple connections back there that connect to those.
noway
Louisville ky
if i need to swap ecu i will. As for the purplr plugs well they jump rite into the main harness there is no connections farther back
noway
Louisville ky
Did i post a picture of the ecu i really dont know what it is lol. Im a carburetor type of guy
noway
Louisville ky
05 ls 2.2 swap to a 06 lt. I have the actual swap dun but the 06lt has a different plug in 2 different locations. Purple plugs on the left is a 2005 with 4 wires and on the right is a 2006 with about 12 wires. The aluminum boxes i dont know what they are called. But the 1 plug wont fit. Can anyone help me 20160323_060006.jpg
The metal boxes are the ECUs, and that's also the reason you're having a problem here. How much exactly did you swap over? The entire engine and wiring harness? or just the motor and ecu?
This ecu is 05-06
This one is 07-10
Plea
