PIP: Hesitation / Stall Engine RPO LAF LAP LAT LNF LE5 LE8 LE9
rukkee
WNY
Service Information
2009 Chevrolet Cobalt | Cobalt, G5 (VIN A) Service Manual | Preliminary Information | Document ID: 2321485
#PIP4469E: DTC P0011 P0014 P0016 P0017 Setting Or Hesitation / Stall Engine RPO LAF LAP LAT LNF LE5 LE8 LE9 - (Jul 31, 2009)
Subject: DTC P0011, P0014, P0016, P0017 Setting or Hesitation/Stall Engine RPO LAF LAP LAT LNF LE5 LE8 LE9
Models: 2009 Chevrolet Cobalt
With RPO LAP 2.2L, LNF 2.0L
AND
2009 Chevrolet HHR
With RPO LNF 2.0L, LE8 2.2L, LE9 2.4L
AND
2009 Pontiac G5
With RPO LAP 2.2L
AND
2009 Chevrolet Malibu
2009 Pontiac G6
2009 Pontiac Solstice
2009 Saturn Sky
2009 Saturn Aura
2009 Saturn Vue
With RPO LE5 2.4L
AND
2009 Saturn AURA Hybrid
2009 Saturn VUE Hybrid
2009-2010 Chevrolet Malibu Hybrid
With RPO LAT 2.4L
AND
2010 Chevrolet Equinox
2010 GMC Terrain
With RPO LAF 2.4L SIDI
This PI was superseded to add the 2009 2.4L LAT and the 2010 2.4L LAF/LAP also to add DTCs P0016/P0017 and hesitation/stall as keywords. Please discard PIP4469D.
Condition/Concern:
In rare instances a technician may comment that they find DTC's for cam phaser operation and or have noticed a hesitation/stumble typically on a PDI or with very low mileage. They may have followed eSI diagnostics and the dtc/condition has returned. They may have replaced the ECM with no change and/or they may find one or more of the DTCs listed below.
P0011-Intake Camshaft Position (CMP) System Performance
P0014-Exhaust Camshaft Position (CMP) System Performance
P0016-Crankshaft Position - Intake Camshaft Position Not Plausible
P0017-Crankshaft Position - Exhaust Camshaft Position Not Plausible
Recommendation/Instructions:
Engineering has determined that casting sand and or non-ferrous (aluminum) machining debris in the camshaft phasers/solenoid valves can cause a hesitation/stumble and or these DTCs to set intermittently. This condition/DTCs typically will set very early in the vehicle's life or at PDI. When the technician follows the eSI diagnostic chart for these codes they may be led to ECM replacement; however additional diagnostics should be made before replacement of any parts. After inspection of the solenoid valve and wiring per eSI confirms correct electrical operation, check for debris. The technician should inspect each CMP actuator solenoid valve assembly for torn screens or debris on the screens, then clean and replace as necessary. If the dtc continues to reset after thorough inspection and cleaning of the solenoid valves, replace the affected camshaft actuator(s) depending upon the dtc(s) that set.
Note: When debris is found change the oil and filter before returning to service, in some instances it may be necessary to change the oil/filter multiple times. The filter can be inspected afterwards to ensure no additional debris is present.
Plea
