06 motor in an 08
brad
rochester ny
My brother inlaw wrecked his 06 cobalt 2.2 liter and we have and opportunity to buy an 08 cobalt with a blown motor. I'm just wondering If its a straight swap from an 06 to an 08?
IIRC they changed the coil packs and a couple other minor changes. Should be able to straight swap so long as they're both the 2.2
brad
rochester ny
it appears they changed the computer in 2007 from 16bit to 32bit is that going to be an issue? according to Wikipedia they changed the block, head, cam, ignition system, and a bunch of sensors too.
Ah right ECU change in 07. If you yank all the sensors out of your 08, put into the 06. Might work.
The best route would be replacing the entire vehicle electronics with the one from the 08. But that's a beastie.
Armando831
California
Did u guys do the swap in in the middle of one i didnt realize i got the lap engine i have a 06 cobalt l61 and noticed diffrent sensors and plugs dont match should i replace the wiring harness and ecu and should it work? Any help plz
Plea
