06 LS Replaced Timing Chain but still same noise
Morgan Price
South Carolina, USA
Car randomly started making this same noise, would get worse if I accelerated, sound comes directly where the timing chain is located. Replaced upper timing chain, sprockets, guides, and tensioner. Replaced lower timing chain tensioner. Still hearing this noise. When troubleshooting, I turned over the engine via crankshaft pulley and seemed the noise was coming from upper chain slapping the top guide. Everything via upper timing has been replaced and both chains are tight. Would it be best to order a lower timing chain kit and replace everything down there as well, or could it be engine internals?
Any help would be great.
Shaggy
Administrator
Who replace the timing belt? Didn't they check the noise before they gave it back to you or did you change it yourself?
Morgan Price
South Carolina, USA
Seems strange to be hitting like that. It it the correct timing chain for the year?
Yes, used Cloyes.
In the process of changing the lower timing. It's a right pain since I have to strip everything down again and ended up breaking the evap solenoid so another thing to do.
Shaggy
Administrator
Yes, used Cloyes.
Always fun! Keep us posted.
