2.2 Ecotec Head toast ... what to do?
derran.m
Not 100% sure yet if it is the head or just the gasket, but it's toast. Wondering if anyone has any connections for a new head?
Also, if it is the head and I have no luck finding a used one ... how hard would it be to swap the engine out all together to the 2.0T?
very hard for a direct injected head :p but if your headgasket is gone, you do need to take your head to get checked, it could be warped, also you'll have to get the block checked aswell
I have a head that is shaved .020" and all it needs is the valve guides pressed out and replaced
it has 15k ish on it
I have other spare stuff including a while spare valve train if you need anything
06ion2coup
Columbia Mo
How much are you guys wanting for these heads? and tom what about yours with the valves replaced?
well the valve guides cost approx 70-100 to replace
id suppose i would let it go with a full valve train in it for 150 plus shipping obo or stripped for 100 plus shipping obo
06ion2coup
Columbia Mo
hmmmm so its shaved .20 over more then stock, what kind of compression ratio would that end up yielding
honestly...no real idea on the numbers except its better then stock hahaha
and that work cost me 60$ when i did it
was done at an AWESOME shop here, same one that build the heads for the SSC Supercar.
im guessing though .5-.75 over stock
ReynaldoPa
