2.2L limited slip???
Jmesl8er
NKY
Do you have one????^^^^^^^ If so, how much of a difference does it make compared to a regular cobalt???
Jmesl8er
NKY
would it be worth installing if you don't race?? would it be better in snow?? would it affect gas mileage?? Never had a front wheel drive with an lsd
It understeers easier but overall drives better with the LSD.
doesn't make a dif in the snow. I had a horrible time in the snow this winter with even with the lsd and traction control. I found it was better to turn off the traction control.
Traction control was designed to limit slip on dry and wet ground, not snow. Any vehicle that has a "Snow" or "Winter" mode disables traction control in that mode. My LSD saved me from calling a tow truck this winter when I spun her doing 15 on ice into an embankment, pulled out without a scratch.
dowienu
re: flanged bushings
I like oem motor mount inserts.
---------- Post added at 08:51 AM ---------- Previous post was at 08:46 AM ----------
---------- Post added at 08:55 AM ---------- Previous post was at 08:51 AM ----------
Mr. Red Pony
Lawton, OK
Lift up both front wheels. Put it in nuetral. Spin one wheel. If the other wheel spin the opposite way, its an open dif. Same way its an LSD.
i did the same thing but my right rear rim took a bunch of scratches from the curb
