2009 Cobalt - Bent rim
AmyF
My husband has a bent rim (he has the stock factory steel rims with the hubcaps) - his tire is not losing air but he can feel the vibration from it. Can a bent rim be repaired or does he need to get a new rim? I was planning on upgrading my 2010 Cobalt to 16" aluminum rims - I could always give him one of my rims at the time I upgrade, but that won't be for probably 6 months or so.
The GRAFX Shop
Canada
most times the rim can be fixed. call your local dealer or tire shop.
iv even seen aluminum rims bent so bad they look like a stop sign and they have been fixed
Hailcesar75
Brooklyn, NY
They can be fixed. Most shops hammer them. If and when u do upgrade I suggest u get 17's instead. They look better. Unless your not planning on modding u balt
can you visually see the bent rim? vibration can also be felt from improper tire balance which typically is a result of losing a balancing weight by hitting a pothole or something similar
