Cruise control availability and steering wheel question
occupant
Westerville, OH
I know LTZ and 2LT models typically all have cruise. I have seen a few 1LT models with it as well. Did any LS Cobalt come available with cruise, maybe earlier 05-06 years? Was it available on fleet models, maybe?
Most of the ones I've been looking at are 07-08 because I like the 3 spoke steering wheel better, but I'll consider an 05-06. Is there any reason the later 07-10 steering wheel could not be used on the 05-06 models? I'm assuming the cruise/radio buttons may work, but I'm also assuming that different airbags may not match up. Did the connectors and clockspring change at all between 2006 and 2007, or just the cosmetic appearance of the wheel and airbag?
---------- Post added at 03:19 PM ---------- Previous post was at 03:05 PM ----------
Found my own answer on the SS forum...
All Cobalts have cruise control. You just need the plastic cover on the left side of the steering wheel, a connector/wiring harness bit, and an hour of Tech II time at the dealer. Voila, you have cruise.
I won't link to the other forum, because it's another forum, but here are the part numbers you need:
$13.79 15234343 connector
$44.64 15845807 left side trim piece for cruise/radio control wheel
$43.76 15845808 right side trim piece for cruise/radio control wheel
$24.44 15942950 cruise control buttons (left side)
$28.92 15942951 radio control buttons (right side)
Total at GMPartsDirect, $155.55 as of this posting (plus any shipping) retail is over $258.
Thank you for this, are you sure you don't have to replace the clock-spring assembly?
occupant
Westerville, OH
Clockspring is the same part 2005-2011 for all Cobalts, HHRs, and G5's regardless of trim level. Same part number also fits Solstice/Sky and 07-09 Equinox/Torrent. PN# 20940100.
Plea
