Driver's window wont roll down- ION
gCobalt05
North GA
Girlfriend has a 2005 ION sedan and her driver's window won't roll down. She has automatic everything.
What shall I do?
outtamymind
Calgary, Alberta
try the switch first whether it be a spare one you have or a new one doesn't matter as long as it's a working one. if that doesn't help then chances are good that its the motor.
sloancallaway
Spruce Grove Alberta Canada
Okay well check your fuse if its good
Pull off the interior door panel check if it switch is connected properly if not it go to the
Wreckers and get a switch I doubt it is the motor
Tom
Houston TX
the Glass could be off track,but I would just take the door panel off and check for any visible damage, torn wires, motor smells smokey,broken mechanical parts etc...
I had a problem with my window seal and it was causing it to knock the window off the track. when the window glass is off the track it cause excess stress on the motor and could have burned out the motor....
GeenaPee
