fastest n/a 2.2
Auburn, WA
huckernage has the fastest 2.2 (ion) i have the fastest n/a 2.2 cobalt right now here
Auburn, WA
wat are ur times ?
wat u got dun ?
so far 14.95 (full interior and driver suck mod lol) @ 95mph. dynod at 180.16 but afr was bad, vince retuned and all est shows approx 200whp (before valve guides blew)
as for mods:
Performance:
Ebay cold air intake
AEM dryflow filter
2.4l intake manifold
2.4l throttle body
stage 2 Comp cams
lsj injectors
shaved cylinder head .020"
Jason Smith strut bar
Clear Image 4-2-1 header
Clear Image 2.5" catless DP
Clear Image 3" catback w/ Magnaflow muffler & resontator
H&R sport springs
SS/TC struts/ shocks
SS/TC Front Sway bar
SS/TC End Links
MRZ lightweight alternator pulley
MRZ lightweight crank pulley
TTR tranny mounts
TTR solid engine mount
TTR rear sway bar
Trifecta Tune
Ebay oil catch can
i have other stuff, but that is the stuff pertaining to the track except that im on 17" adr phantoms w/ 225/45/17 nitto neogens (at the time of the run i was on kuhmo ecsta 205/35/17's)
since the valve guides are pretty well shot on this cyl head im pulling engine this winter and doing the following:
stg3 port and polish
port match intake and exhaust
clean up intake mani
port & polish TB
shave head more
cometic thinner head gasket
1mm oversized valves
si valve train w/ heavier weight capacity valve springs
eagle h beam rods
cleaned up pistons
piston ring replacement and honing of cyl
new seals all around
and a redyno tune by vince
all est of this build should put it at 240whp+ and with a good driver mod and track i should be LOOOOOOOOOW 14s on the track if not better ;)
